Company management and provisioning guide for MSP partners
Working with managed companies
You can view all managed company accounts in the Companies page, together with information regarding the company, products used, and licensing. The information is displayed under multiple columns.
Additionally, you can perform the following actions:
Editing companies
To edit a company account, follow the steps below:
Log in to GravityZone Control Center.
Go to the Companies page from the left side menu.
Click on the name of the company you want to edit.
The Edit Company window is be displayed. The information is organized into three tabs:
In each tab, make the changes you want and Save. You need to save your changes before switching between tabs.
If the selected company has not enabled the The Company's Partner can assist with the security management option, you will not able to modify specific settings and information.
Close the Edit company window by clicking the X button on the upper right side of the screen.
Suspending and reactivating companies
If you are no longer doing business with a company, you can suspend their account. If that company has child accounts, you have the option to suspend them at the same time.
Suspending only one company account will not automatically affect the accounts created from the suspended account. Those accounts will continue to work as before.
Choosing to suspend a company account together with its child accounts will render all those accounts unavailable.
Suspending a company has the following consequences:
The company users cannot log in to Bitdefender Control Center
The endpoints directly managed by the suspended company are expired.
Only the endpoints that have been protected with the Bitdefender security agent installed from a kit specifically created for the suspended company are expired.
Bitdefender security agent is not uninstalled from the expired endpoints. Once the company is reactivated, all expired endpoints will be automatically registered.
When reactivating a company account, you have the option to activate all its child accounts at the same time.
To suspend a company account:
Select the company account from the list.
Select the More actions menu at the upper side of the table and click Suspend.
To suspend all child accounts under the selected company, including those managed by other child companies, enable the Suspend all companies under this company as well option.
Click OK to confirm. The company account state will change immediately. Users linked to a suspended company will no longer be able to log in.
Reactivating a company
To reactivate a company account:
Select the suspended company account from the list.
Select the More actions menu at the upper side of the table and click Activate.
To activate all child accounts under the selected company, including those managed by other child companies, enable the Activate all companies under this company as well option.
Click OK to confirm. The company account state will change immediately. Users linked to a reactivated company will be able to log in again to Bitdefender Control Center.
Checking the company status
Each company is represented in the Network page under the Companies section by an icon specific to its type and status, described herein:
The icon shape informs you of the company account type:
Icon
Description
Partner Company
Customer Company
Blue color shows who manages network security:
Icon
Description
The company self manages its network security.
The Partner manages the company's network security.
The cross sign informs of the company account status:
Icon
Description
Active
Suspended
The exclamation mark informs you of the security issues in the company'snetwork:
Icon
Description
Without issues
With issues
For example, from a quick view, the icon informs you that the company is a customer who self manages its network security and the account is suspended.
Deleting companies
Delete company accounts when they are no longer needed. For example, if a company no longer uses Bitdefender protection or a partnership ends.
To delete an account:
Log in to Control Center.
Select the companies you want to delete.
Click the Delete button above the table.
Click Delete to confirm. The company account, its linked user accounts and its license keys are deleted from the database.
You cannot delete partner companies with subordinate company accounts.
